Audio recording
Dibbler99
Explorer
Audio recording
Is it possible to connect an audio source like a speaker output from a movie projector directly to a HDR-CX405 so that I can convert a sound movie from 8mm film directly to the camera ?
Nobody got any ideas ?
On my movie projector there is a "Line output" socket and a "Speaker output" socket, Maybe I can use one of these, but where do I connect to the CX405 and can I be sure that I will not damage the camera?
2 REPLIES 2
Dibbler99
Explorer
Is there anybody there ?
It's now two weeks since I posted this. I wouldn't mind a reply even if it is to say "no"
IamNic
If it has a microphone input, you can capture any audio source you can narrow down to a 3.5mm stereo audio plug.
- Nic
