DCR-HC24E CD ROM
profile.country.en_GB.title
pammy1961
Visitor
DCR-HC24E CD ROM
Can anyone tell me where I can get a copy of the cd rom that comes in the box with the camcorder? I have just come back from my holidays and want to put my video's on my computer. Hopefully someone out there can help me.
Tags (1)
2 REPLIES 2
Blencogo
The original software will only work with Windows XP.  If you are using Vista or Windows 7, see what is available from here: -
http://support.sony-europe.com/dime/camcorders/sd/dv/dv.aspx?site=odw_en_GB&m=DCR-HC24E
:thinking:
profile.country.hr_HR.title
DamacizSi
Visitor
U can use Windows Movie Maker via I link cable which protocol is IEEE1394. On program you go to function chaptering from video device, which is first left in program. On camera set option play-edit.
http://explore.live.com/windows-live-movie-maker?os=winxp
There is free download on internet, if You use Windows 7
There are 4-4 and 4-6 pins I link cable. Sony cameras are always 4 pin, but see DV IN in Yor PC. If You do not have DV IN, there are cheap USB - I Link adapters.
Deinstall K-lite and free codec packs.
Regards
Damac
:slight_smile:
