BDP-S1700 wired internet fail
pixelat0r
New
Please can you help?
Every few weeks this thing drops its wired internet connection for no apparent reason after working fine previously. It tells me a network connection cannot be made and, after running an "auto" setup I get.
Physical Connection : OK
Internet Connection: Failed
I generally try to sneak out of workto ring Sony who tell me it's a known problem, talk me through some manual settings and like magic it works again for a couple more weeks. Problem is I'm so busy putting the settings in I never think to write them down. They can't be router-specific settings as they never ask for details of my router.
The whole thing is now getting very old and I'd love to return this peice of cr@p but I've had it since May 😞 It always happens at weekends when support are closed which doesn't help.
I don't suppose anyone out there knows the magic settings that Sony gives me do you?
5 REPLIES 5
Anonymous
Not applicable
Hi there
I am finding out if it is indeed a known problem - as I cant recall others posting about this.  Also, im finding out the steps needed to fix it (at least for a while).  Will post back when I get this information.
Cheers
Eddragon
New
I have just bought this product. It plays DVD through tv no problem but fails to connect to the internet for apps. I have connected by cable to my BT router. The device knows it is connected by cable but reports connection failed. It has never made a connection. What can I do?
Anonymous
Not applicable
Hi there
Try manually setting a 'static' IP address on the bluray player - its worked for at least 2 others.
See:
https://us.en.kb.sony.com/app/answers/detail/a_id/35254/
Cheers
Mikeyj63
Explorer
Got the same problem since I moved from BT to Sky broadband router
Tried updating firmware - since no internet, had to get a friend to do so via his broadband.
Changed the ip address, dns and gateway, but still no luck - internet access failed.
Will try the helpline to see if they have any bright ideas
Mikeyj63
Mikeyj63
Explorer
Firmware version - M30.R.0433
