BDP-S370 appears to be unable to play avi files via DLNA
SOLVED
profile.country.en_GB.title
williamh1
Visitor
I've just upgraded my pc from Vista to Windows 7. With Vista the BDP-S370 was able to identify and play avi files via DLNA. However after the upgrade to Windows 7 the player appears to be able to identify the files as avi ones but then when I try to play them the corrupt/unsupported message appears on screen. ANyone have any thoughts on what I might be doing wrong. BTW when copied to a pendrive the avi files play perfectly when the pendrive is plugged into the front of the BDP-S370.
1 ACCEPTED SOLUTION
Accepted Solutions
Catmambo
Contributor
Probably haven't got your new version of windows setup for streaming. Just install Serviio on your machine and it will take care of the streaming part comfortably..
Thanks
2 REPLIES 2
Catmambo
Contributor
Thanks
williamh1
Visitor
Cheers Cat...., that's done the trick. Thanks for your help.
