BDV-N9200W help (and general whole setup)
Deano777
New
I have recently upgraded my entire gaming setup and need some tech savvy people to help me out.
Firstly I will say what the upgrades are. It may be helpful in case someone else has these models.
I have purchased a Ps4Pro, simple enough.
Next I have purchased a new 4k enhanced Epson EH-TW7300 projector, I don't use TVs.
Finally I bought a Sony BDV-N9200W Home Cinema System.
The issue is that while the projector has a method to output 4K images and the cinema system has 4k pass-through, I can't get them to work together.
I can have the projector connected to the Pro via HDCP 2.2 HDMI and that displays the image as it should albeit only 2K but allows me use of HDR and Deep Colour Output options, however that means the cinema system is not connected so I have image but zero sound.
When I run it through the cinema system too then to the Pro, I get great sound but the PS4 says that the projector/ TV isn't 2.2 compatible which it is, so I only get HD capabilities and lose HDR and DCO.
It doe's allow me to use the 4K enhancement feature but not the HDR (as that requires 2.2) and I can no longer stream 4K content from Netflix for example.
Granted it up-scales it, i'm sure it would be better if it actually received the 4K source instead.
So really the question is how do I make it all work as desired at the same time?
Sorry if this is a very specific problem but any help would be very appreciated.
1 REPLY 1
Peter_S.
Genius
Hi Deano,
Unfortunately the BDV-N9200W is not HDCP 2.2 ready… it can pass through 4K 24p signal (fulfil under HDMI 1.4 standard) but not the 4K high bitrate HDR with HDCP 2.2 copy encryption.
So best you can do is to connect the PS4Pro directly to projector by HDMI and then using the optical output port to connect to the BDV-N9200W.
Hope you find this answer helpful
Cheers
Peter
