HDMI soundbar issue
SOLVED
chhalle86
Explorer
HDMI soundbar issue
Newly purchased a Sony 55xd8599 tv and HT390 soundbar. Worked for two days through HDMI. Couldn't get it sorted after without optical connected, Sony sent engineer out TV HDMI port suspected as faulty, replacement new TV arrived. Setup and again worked fine for 5 days this time now AGAIN not working reset both devices still not working.
any ideas welcomed both I contact SONY!
1 ACCEPTED SOLUTION
Accepted Solutions
chhalle86
Explorer
Went straight to end suggestions, problem caused by TIVO box needing re-setting. Will see how long it lasts this time.
Surprised Some by did not suggest re-setting TIVO box FIRST since TV did not need re-setting at all. They now have a TV back that probably did not need changing.
Thanks
Sent from my iPad
7 REPLIES 7
Anonymous
Not applicable
Hi there
It would be highly rare to get two TVs with the exact same problem.  So I am assuming the issue is at your end somewhere.  Can you try going through these instructions and see if it helps:
https://community.sony.co.uk/t5/android-tv/hdmi-problems-troubleshooting-steps/td-p/2141941
Cheers
chhalle86
Explorer
Thanks
Sent from my iPad
Anonymous
Not applicable
Hi there
Glad it was as simple as that.
Cheers
jocie132
Explorer
I have the KD 65A1 and am having the same issue with a Panasonic Theater audion sound bar.  If you disconnect teverything from the mains, wait one minute then restart, the TV recognises the sound bar, if you turn off and on again, it still recognisses the bar.  However if left for more than approximately 1 hour, the TV then has forgotton the connection and then you have to repeat above.  Not good enough for a £5,000 tv!!
jocie132
Explorer
I have the same issue. If you disconnect from mains and turn back on the bar works, but the TV forgetts it after one hour, then you have to repeat.  Not good enough for a £5000 tv !!
jocie132
Explorer
although shutting down from the mains, this does not solve the ptoblem, because it keeps accuring as soon as the TV is off or on standby for more than appx 1 hour.  You should not have to do this on a TV of this price.  It is not acceptable and I too am extremely anoyed to say the least.
chhalle86
Explorer
Had issues with Virgin often after updates, longest time without having to switch off to completely 2 weeks.
Now with BT only issue is remembering to turn devices off onto standby in correct order. However, both devices message going into standby and therefore still need both controller.
Chris
Sent from my iPad
