Problem with HT-XT2 Soundstage playing Blu-Ray Disc
walshes56
Explorer
Hi ,
i am new to this forum , could someone help?
The problem I have had for the last two years is when playing a Blu-Ray Disc, there is no sound
on my tv until I turn the soundstage off.
I have a Sony blu-ray player (3500) & a Sony 43" Android tv , all connected thru HDMI Cable of which are good quality .
playing DVD is no problem ,I have a good sound coming thru  the soundstage plus skyHD & Digital.
everything has been checked many times.
the only sound I get thru the soundstage playing Blu-Ray is English descriptive audio plus
foreign audio .It does not seem to play the 7:1 Dolby signal on Blu-Ray.
i think this was mentioned in the hand book, can anyone confirm. the soundstage is updated regularly & seems fine.
1 REPLY 1
cass_n
Hi @walshes56, welcome to the community :slight_smile:
It might be that the HT-XT2 doesn’t support the audio format of your Blu-ray Discs.  You could try enabling the Dolby D compatible output in the settings of your Blu-ray player and see if this solves the issue.
Cheers,
Cass
