TV goes black, restart & black again
SOLVED
Sipnone
New
Hi I have a Sony KDL - 32S5600 which has a problem.
It started with turning off and on again sometimes.
Then one day, it made something something like an electrical off sound and went off.
So after that, when I am turning on the TV (the led button of power works, going green as normal),
it's completely black, it's turning off and on again with the same procedure.
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
Hi there
Unfortunately it appears that your TV has developed a hardware fault and will need repairing from an authorised Sony repair centre.  However considering the age of the TV, it might be that its un-economical to repair - hence cheaper to purchase a new one (assuming parts are also still available).
See:
http://services.sony.co.uk/support/en/repair/asc
Cheers
1 REPLY 1
Anonymous
Not applicable
Hi there
See:
Cheers
