Hardware problem in VPCCB3C5E
SOLVED
profile.country.en_GB.title
Ahmed0Al-Hebshi
Visitor
Hi
I have VAIO E Series Laptop model name VPCCB3C5E (soutmised)
i have upgraded to windows 8 a while ago but as shown in the attatched image still facing some unidentified hardware i have looked to all the drivers that Sony support and all around the internet,but non of these fix the shown and highlighted unidentified hardware.
please help me
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
Hi Ahmed,
There are similar models to yours sold in the USA/Canada – Vaio C series. Support for these models includes full drivers for Windows 8 (as opposed to the upgrade drivers offered by Sony Europe. Included is the Ricoh Memory Stick Driver Ver. 6.20.13.30 which is the same driver version as the European site but has a size of 1.88 MB as opposed to 1.7 Kb.
http://esupport.sony.com/CA/p/swu-download.pl?mdl=VPCCB32FD&upd_id=7887&os_group_id=24
This will hopefully be the base system device.
If not then right click the device > select Properties > Details tab – on the drop down menu select Hardware Ids and let us know the value listed which will take the form of, but not necessarily the same as, PCI\VEN_1180&DEV_0592&SUBSYS_9040104D&REV_12
Do the same for the unknown device in the hope that the hardware Id will give us a clue as to the driver needed.
Here is a link to Canadian support for the VPCCB32FD – you need to select the operating system to see relevant drivers.
http://esupport.sony.com/CA/p/model-home.pl?mdl=VPCCB32FD&template_id=1®ion_id=3&tab=download#/downl...
You may also find the ‘Windows® 8 Clean Install Instructions for VAIO® PCs’ of interest:
http://esupport.sony.com/CA/p/support-info.pl?info_id=1202&mdl=VPCCB32FD
Hope this helps.
Rich
Message was edited by: rich912
Added missing link.
Go n-éirí an bóthar leat
18 REPLIES 18
rich912
Contributor
Hi Ahmed0Al-Hebshi,
Your model is fully supported for upgrading to Windows 8 and all drivers are available. However if you carried out a clean install the drivers provided will not install as they are upgrade versions.
Only a migration from Windows 7 is supported by Sony Europe. If you have not already done so, I suggest you read the sticky on this subject.
https://www.sony.co.uk/discussions/message/1301477#1301477
Rich
Ahmed0Al-Hebshi
Visitor
Thanls Rich
so i have to install back windows 7 and after that install windows 8 without formating anything so have all the drivers working.
ahmed
Message was edited by: Ahmed0Al-Hebshi
rich912
Contributor
Hi Ahmed,
Yes, to upgrade/migrate to Windows 8, as supported by Sony Europe, the complete Windows 7 system, including recover partition must be in place – restoring to factory settings will achieve this. Hopefully you created recovery media as a clean install of Windows 8 may have deleted the recovery partition.
Rather than downloading all upgrade drivers from the Support site it may be easier to order the upgrade kit from Sony.
https://ebiz3.mentormediacorp.com/sony/windows8/EU/index_welcome.aspx
This can be downloaded or ordered as a DVD.
Rich
Ahmed0Al-Hebshi
Visitor
Hi rich
I tried to get the VAIO UPGRADE FOR WINDOWS 8 kit but it tells me that my vaio is not supported.
rich912
Contributor
Hi Ahmed,
Unfortunately, after checking, this would seem to be the case. The VPCCA4xxx is fully supported and eligible for the kit, the VPCCA3xxx is fully supported but just from the Sony Support download area.
Sorry for misleading you.
Rich
Ahmed0Al-Hebshi
Visitor
Hi Rich
So, i just follow what i said
"so i have to install back windows 7 and after that install windows 8 without formating anything so have all the drivers working."
Or you suggest something else
thank you
rich912
Contributor
Hi Ahmed,
Yes, as far as I am aware that is the only way to be able to then install the upgrade drivers from the Support site. Also during the Windows 8 upgrade process you must opt to Keep Windows settings, personal files, and apps.
Rich
Ahmed0Al-Hebshi
Visitor
Hi Roch
I have ried exactly what you advised me but it give me more problems for direct upgrade without formating windows 7 drivers, so i have to go back to clean installation for windows 8 , right now i have the same drivers showing in the first post excluding the bluetooth driver which is working just fine
only the can idintidy the "Base System device, and unkonw device"
please help me
rich912
Contributor
Hi Ahmed,
Hope this helps.
Rich
Added missing link.
