Hardware problem in VPCCB3C5E
SOLVED
profile.country.en_GB.title
Ahmed0Al-Hebshi
Visitor
Hi
I have VAIO E Series Laptop model name VPCCB3C5E (soutmised)
i have upgraded to windows 8 a while ago but as shown in the attatched image still facing some unidentified hardware i have looked to all the drivers that Sony support and all around the internet,but non of these fix the shown and highlighted unidentified hardware.
please help me
18 REPLIES 18
Ahmed0Al-Hebshi
Visitor
Hi Rich
Thanks alot you helped me alot since long time i was strggling
the Base System device is working
but cant find for the "unkonw device,Hardware ID is ACPI\VEN_SNY&DEV_5001"
thank alot Rich
rich912
Contributor
Hi Ahmed,
ACPI\SNY5001 is the Sony Firmware Extension Parser Device (SFEP). Even on the Canadian site there is no update for Windows 8 so I suggest you try installing the original Windows 7 version from the Sony support site – it is listed as SFEP Driver.
http://www.sony.co.uk/support/en/product/VPCCB3C5E/updates
Rich
Go n-éirí an bóthar leat
Ahmed0Al-Hebshi
Visitor
Hi Rich
Thanks alot i have tried the Firmware Extension Parser Device (SFEP) for Windows 7 but it dose not work..maybe sony will relase for windows 8 soon
thank alot Rich
rich912
Contributor
Hi Ahmed,
This is a long shot, but it may be worth trying to install the SFEP driver that comes pre-installed on a Vaio model released with Windows 8. One such model is SVE1713Z1RB and you can find the driver here:
http://www.sony.co.uk/support/en/product/SVE1713Z1RB/updates
Rich
Ahmed0Al-Hebshi
Visitor
Hi Rich
same thing not working with this model
thanks Rich
rich912
Contributor
Ah well it was worth a try. Don’t hold your breath on Sony providing the driver in the future…
Ahmed0Al-Hebshi
Visitor
Ahmed0Al-Hebshi
Visitor
just a question the Canadian support for the VPCCB32FD drivers and utilities is it fully compatible with my model....
thanks Rich
rich912
Contributor
Hi Ahmed,
At a glance yes, but you would need to check that all hardware secifications match to be sure.
Rich
Message was edited by: rich912
