High capacity battery for AR51M
jaylfc1980
Visitor
Hi everyone!
Just after a bit of advice really. I'm looking for a hi-cap battery that will be compatible with my AR51M, does anyone know of one or know the part number of one? Would prefer a 7200mAh if pos.
Thanks for your help!
3 REPLIES 3
Thalamus.
Champion
Hi jaylfc1980,
as far as I am aware the batteries used in the AR51M are -
Standard capacity - VGP-BPS2C
Larger capacity - VGP-BPL2C
When searching be aware than some retailers sell non Sony compatible batteries with the same battery model number..
jaylfc1980
Visitor
Hi jaylfc1980,
Thanks very much Thal.
My own research turned up the same results, just that some retailers listed these as AR51M compatible and some didn't so was seeking confirmation here.
I'll get ordering then!
Again, thanks very much! :slight_smile:
Thalamus.
Champion
You're welcome jaylfc1980.. :slight_smile:
