Just bought a vaio, it keeps shutting down when in use with no warning, is it broken and in need of a repair?
SOLVED
profile.country.en_GB.title
DaRobb
Visitor
question, just bought a vaio, keeps shutting down when in use with no warning, does it need a repair?
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
Hi DaRobb,
You could try returning the notebook to factory settings by tapping F10 at boot to access the recovery utility – select 'recover complete system'.
If that doesn’t resolve the issue then contact Support for a repair.
Rich
Go n-éirí an bóthar leat
1 REPLY 1
rich912
Contributor
Hi DaRobb,
Rich
