Screen turns off by itself and clicking sound from the hard disk
engyong
Visitor
Hej,
I have been using Sony Vaio VGN-FW31J since last year June. This week I noticed that the hard dsik produced weired sounds. First it was as loud as fan sound, then today the clicking sound begin. I am afraid the hard disk is going to die. Then the display backlight blinking and turned off by itself several times today. I closed the lid and logged on and the screen went dark until several times trial, the problem went away. The screen still blinking now and then this evening.
EY
4 REPLIES 4
Blencogo
Hi EY,
It sounds like the power board is failing.
I would contact Sony Support as soon as possible to arrange a repair while you are still withiin warranty.
:slight_frown:
engyong
Visitor
Hej Blencogo,
My Sony run dual systems: Windows Vista (original) and Windows 7 professional (installed 3 months ago). Should I uninstall the Windows 7 prof before the returning?
EY
Blencogo
It is up to you. This cannot be a software problem causing this.
I don't think you must remove Win 7 but Sony Support may reformat or replace the drive so make sure you back up anything important.
:thinking:
engyong
Visitor
Okay. Thanks.
