SMART predicted harddisk failure
SOLVED
profile.country.en_GB.title
omkarmedicine
Visitor
my laptop vpceb14en reporting samsung HM321HI failure but drive functioning properly.how to repair or alternative solutions
Message was edited by: omkarmedicine
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
Hi omkarmedicine,
Firstly back up your data and, if you have not already done so, create your recovery media.
The drive has reached a threshold level of hardware error report and cannot be repaired using utilities such as CHKDSK.
The drive may continue to function for a while but may fail at any time.
Rich
Go n-éirí an bóthar leat
2 REPLIES 2
rich912
Contributor
Hi omkarmedicine,
Rich
Aalya757
Visitor
Hi, For the safe side firstly take the back of all your data as your hard disk is about to fail or if find difficulty in doing so just consult to data recovery sevices expert. They will properly guide you in this regard.
