Sony VAIO XL302 BIOS Post "beebs"
profile.country.en_GB.title
jimhunt
New
Hi,
after years of faithful service my Sony VAIO XL302 wont power up after we had a mains power supply failure the other night.
On powering the XL302 on all I get is an endless series of long "beebs" from the motherboard.
I've tried resettimg CMOS using the jumper and i have replaced the backup battery - with no improvement
Can anyone let me know what the XL302 POST and beep codes mean?
Thanks!
Cheers, Jim
2 REPLIES 2
Blencogo
Hi Jim and welcome.
Sounds like it is likely to be a power issue.
Have a look at the BEEP Codes here: -
http://www.computerhope.com/beep.htm
See if you can identify the sequence of beeps.
Come back if you need help after identifying the code.
:thinking:
jimhunt
New
Hi,
Thanks for the quick response and trying to help!!
I've had a look at that reference, but unfortunately each manufacturer's BIOSs seem to be different. I was hoping to get the specific codes for the Sony VAIO XL302 - unless of course I have missed something obvious!  :
Thanks, jim
