Hi,
55.0.A.2.314 was uploaded just today. As usual no change log whatsoever. Does anybody know if it has just a security patch or other improvements ?
So frustrated that no details are shared.
Solved! Go to Solution.
Dowwnload Xperiafirm
Will tell you who has it or not.
In the UK o2 and EE have it, but not vodafone
so if you are on vodafone, that is the reason why.
If anyone is interested 314 has for vodafone has just appeared on Xperifirm, so shouldn't be too long until devices can download it.
There's a 332MB update on my Vodafone provided phone, I assume this is the latest firmware.
Hopefully it fixes the useless fingerprint sensor.
Cheers for the heads up mate
Excellent news! I have yet to use my phone but glad the engineers/programmers jumped on rectifying software faults once the complaints started rolling in. I'm sure there will be further updates in the pipeline.
Just updated mine
Initial honest impressions:
Impressed by the camera speed launch.
Quicker auto focusing
In auto mode its MUUUUUUUCH quicker to swtch between lenses
Saves a file quicker also, once a photo has taken (around 1 second no compared to 4 before)
Issue still to be changed
IN full manual still photography mode, you cannot switch to the WIDE angle, bit of a pain but not a deal killer.
Stabilisation in video is still to be tested though.
Much better work on this patch Sony and well done to your RND team, however much more is yet to be done:)
BEFORE (taken last week)
https://www.youtube.com/watch?v=TaGKcwUDSHM
I will do the after when i finish work,
@GilgameshUK wrote:Quicker auto focusing
This is good news, I found the camera utterly frustrating when trying to get it to use the 2x lens, and I found the autofocus to be quite unreliable as well when you tap the screen to tell it where you want to focus.
Have there been any improvements to the quality of the JPG's? The compression was quite heavy before, and if I want to take raw photos I'll use my Panasonic G9!
Have not tested for quality difference in photos before.
I have never had any problem with the photos, as you cna see by my photography thread.
Only time I have had noise issues is when I have used 'DEHAZE' in my photos ,as that always bringsi n lots of grain.
still no 21:9 camera mode
Camera image processing now from 7 seconds change to 4 seconds
Camera turned on speed still very slow
Speaker still cracking sound while turning volume up or down
/t5/Xperia-1/xperia-1-speaker-cracking-sound-while-turning-volume-up-or-down/m-p/1381355#M1910
Album now sometimes stuck a minute
Fp reader is still same, difficult to use
Smoother ui
2X digital zoom issue not fix
hongkong firmware update lastnight ,feel the same as above post.
Send to after-sales service now,the FP ready just not right
