Connecting Xperia 1 to pc
Seraph1
Visitor
Hi,
Im having big problems with connecting my Xperia 1 to pc for file transfer (old photos, music etc). I updated all drivers for windows 10, but after connecting pc just isn't doing anything. Its doesent even seeing aby nie device connected. What to do? Please help with this.
Im very sorry for broken english-not my native language.
2 REPLIES 2
RuneJ
Contributor
If your USB-cable is OK, you should see a Access Permission dialog on the phone when connected to the PC.
-Nothing will happen/be visible on the PC before you grant access on the phone.Smiling_Face_with_Sunglasses
Bebuthanh
Visitor
You need to make sure your cable is OK
And when you plug it in the PC, on your device it will show some option like : Just charging, Transfer file .... You need to choose Transfer file
