Google pay doesn't work with telenor provider in Norway
Marcad
Hi,
I have Sony Xperia 1 and google pay doesn't work with telenor provider in Norway, it works fine with another provider such as Telia.
#xperia1
#xperiaxz1
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
RuneJ
If you have a dual-sim phone, insert the Telenor SIM in SIM#2 position in phone.
It will then work fine.Smiling_Face_with_Sunglasses
(The downside is that you cannot use a SD-card as SIM#2 position occupies the SD-card slot)
4 ODPOW. 4
Uliwooly
@Marcad
That's rather odd, does it work fine with WiFi?
when you say that it doesn't work, could you elaborate? how strong is the signal? are you on 3G or LTE?
Marcad
I have tried different sim card with different provider and tried with Xperia xz1, Xperia 1 og Galaxy s8. Only sim card with telenor network didn't work(tried with the xz1 og 1).  I have tested in the same shop. I have successfully paid with the telenor simcard with galaxy s8.
Its LTE
RuneJ
Marcad
It works, but it's little bit annoing,
Anyway doesnt fix the problem on single sim card phone, luckily Telia sends dual sim 😃
Thanks for your help
