Issues with Google Store and Apps
Qubyte
Visitor
Hi!
I've recently updated to the most recent software update for the Xperia 1 and I've been having a torrent of app errors.
For starters, can't install or update anything through the Google play store. Can't open some of the apps that belongs to Google, for instance; messages and Fit.
Any help would be appreciated, I want to try and avert from resetting to factory settings.
Thank you!
4 REPLIES 4
Karim
Contributor
What do you mean by you can't open.... some pics or error message would be helful.
Martin1
Enthusiast
Hi @Qubyte, let me see if I can help out here.
As @IA64 mentioned, it would be great if you could elaborate your question a bit. Do you receive any kind of error message when you try to open the apps in question or do they simply not open?
Please return with a more elaborate question and I will do my best to assist you! Slightly_smiling_Face
Qubyte
Visitor
I seem to have sorted the issue, I uninstalled or Cleared Data on Google Play store, services and all the apps that were having issues. Switched my Network to Mobile and then reinstalled updates which seemed to do the trick.
Martin1
Enthusiast
Thank you for posting the sollution, I am glad that you managed to make it work, @Qubyte!
Feel free to return if you have further questions! Slightly_smiling_Face
