sketch file Xperia transfer F 3111
profile.country.FR.title
Stanzogao8
Hello, My old Sony F 3111 device is broken 😕
the screen is cracked, and only lights up at 10%. I would like to review the old Sketch projects that I had saved on the application portfolio would be savable, via USB data transfer to a computer for example?
Thank you !
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
profile.country.NL.title
Strampke
I'm afraid I cannot locate the files.
However you can export them.
After that you should be able to retrieve and download the files.
4 ODPOW. 4
Strampke
It should connect easily.
On a cracked screen you can use a mouse to command your smartphone, either with cable or  with USB.
Stanzogao8
thank you for your answer ! It turns out that the folders on sketch are missed by the transfer of data. Do you think it exists some other ways ?
Thank you again !
Strampke
Stanzogao8
Yes you're right !! thank you a lot for your answer !
