Companion previously worked fine before my Xperia 1 was updated to Android 10. However today I have tried to move music exactly the same way as I have done before but I keep getting an error. Is there a bug since the windows 10 update?
As always I add music into a playlist on iTunes and then using companion transfer that music to the phone, but no matter what I try it just says there is an error.
Any help and assistance will be greatly appreciated.
Thank you in advance.
Seems like this could be a way forward:
https://www.consumerreports.org/smartphones/how-to-play-itunes-music-on-an-android-smartphone/
Hi thanks for the reply, unfortunately that is something I want to avoid. It was working fine before the Android 10 update. Was wondering whether there was a bug and someone knew of it and had a resolve.
Great alternative.
I used to have a iPhone and for music I had everything on my iTunes account.
Since I have switched from iPhone to Sony Xperia 1 II, I'm going to try out your advise.
Thanks!
This does not work anymore. Google Music has changed to YouTube Music
