Zoom inphotograhpy app
profile.country.NO.title
knutivar
Except from in basic mode I'm not able to zoom in the photo app when I'm taking pictures with 16mm or 24mm lens.
Pretty sure this worked earlier, what can I have changed that has locked down the zoom on those lenses?
PS! The lenses are ok, they zoom like a charm in the videoapp
2 ODPOW. 2
Anonymous
Nie dotyczy
Hey @knutivar
What about other photography apps?
Did you try to clear caches and data for the photography pro app?
knutivar
Zoom works, as mentioned, in the video-app
It's possible I have found the "as-is" solution, just select .JPG instead of .RAW and zoom works. Possibly a strange limitation in the photoapp
