Xperia 10 overheating after update software (April 2019) while mobile data on
ars17
My Xperia overheating while mobile data on, how to fix it? i hope next update can be fix
1 ODPOWIEDŹ 1
Uliwooly
@ars17
The phone can't overheat, if the phone gets too hot it will shutdown. The problem might be background apps constantly syncing which will heat up the phone and drain the battery
But do elaborate as much as possible
