Anyone know how to close apps your not using anymore ? Sony Xperia 5
Hi @Dfc23, let me see if I can help out here.
Do you wish to disable apps that you are not using or do you want to prevent apps from running in the background? If you want to disable the apps, please follow the instructions provided by @uliwooly.
If you want to close an app in order to prevent it from running in the background, swipe up on the home button or tap the recent apps icon in the navigation bar to see the recently used apps, after this you should be able to swipe the app that you want to close upwards in order to close the app.
Let me know if that helped!
