For the past couple of months, I've been having a 1 on the Message app icon, that I cannot seem to get rid of.
I've checked everywhere, I've got no new unread message. I restarted phone, marked all messages "as read" in the app, but nothing seems to clear this 1 new unread message
I tried all I can think of, including all from the below site...
fix-android-device-showing-unread-sms-messages/
Can anyone help provide a solution that actually works?
Thanks in advance
Hey @DavidH41, have you tried clearing the messages app cache (Settings - Applications - All apps - Scroll down to Messages app - Storage - Clear cache & data - Force stop), then force restart your phone (press and hold power and volume+ at the same time) and check again. Hope this works.
@Piscie , yes I have tried this already, but no such luck.... But I tried again after I read your reply just to make sure, and still not sorted
Hi @DavidH41 and welcome to the Community
There are a few other threads on this forum regarding this and
unfortunately we haven't been able to solve this puzzle.
One other suggestion after trying all the above was to get someone to message you and after opening that message it may clear the the message icon, however someone tried this and it didn't work for them.
My wife has this problem on her Xperia and the dot on the message icon does disappear randomly then reappear.
I can't honestly remember if anyone tried a factory reset or not, however this would seem like using a sledgehammer to crack a peanut, especially if the problem reoccurs afterwards. Hopefully another member may hold the key to unlock this door for us.
@jumpsuit I could possibly try a factory reset at the weekend when I have more time, and let you know the results.... The other theory with having someone message you didn't work for me either.
Thanks 👍
Hi @DavidH41
Thanks for trying, it really is a puzzle.
I honestly wouldn't bother factory resetting just for this, its probably more bother than its worth.
(Especially if it starts again after any reset.)
It's ok, I've been made redundant and finish tomorrow, so I have a little free time on my hands 🙃
Oh jeeez, I'm really sorry to hear that.
Hope things get better for you soon!
Hey @DavidH41 keep us updated with the results of the factory reset, hopefully it will fix the problem.
