apparently, in the latest 5v, there is the possibility to use the android 15 private space functionality. Unfortunately, I couldn't see anything relevant in the settings.
https://biggo.com/news/202501160902_sony-xperia-5-v-android-15-update
Key New Features:
Hi @uybhege, yes, you're right.
- Find and tap [Settings] > [Privacy] > [Private space] and unlock the screen.
- To set up private space, you need to set the screen lock beforehand.
- Tap [Set up] and follow the on-screen instructions to set the lock method for private space.
- Tap [Private] at the bottom of the app drawer and unlock private space.
- Tap an app icon.
- To change the lock method or timing or delete private space, tap (Settings icon).
Tap (Install icon) and follow the on-screen instructions to install an app.
when I go into:
no [Private space] option does exist!
Here is the list with the options I get:
Android System Intelligence
Privacy dashboard
Permission manager
Notifications on lock screen
Autofill service from Google
Show media on lock screen
App content
Show clipboard access
Health connect
Activity controls
Ads
Usage & diagnostics
Also, when I search in settings for "private" I only get: "Private DNS"
My screen lock is set to "Pattern"!
Thank you
Hi @uybhege, did you make sure that you have the latest version? check this link to help you update your phone: https://helpguide.sony.net/mobile/xperia-5m5/v1/en/contents/update_device_wirelessly.html If it's updated, restart your phone and check again.
I think I do have the latest available! Looks like that:
but still no "Private space" option is shown!
even after the latest update (= 67.2.A.3.2) no "Private space" option shows up in the list!
Hi @uybhege, you can try these steps.
If the issue remains my friend, you will need to speak to the Sony's technical team: https://services.sony.co.uk/supportmvc/en/contact/
no "Cached data" option exist!
@uybhege It' supposed to allow you to delete cached data, however I guess you should contact Sony's tech team to check it for you.
