отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
A9iii Focus Hunting
Kangolman
Исследователь
A9iii Focus Hunting
I had an issue at a recent wedding where I used my 16mm Samyang for some wide shots. The focus was was proper struggling to lock in and was hunting back  and forth. Lighting wasn’t the brightest but it was by no means challenging. I had AF-C and was around F5.6
1 ОТВЕТ 1
MaggieGreene
Hi @Kangolman, do you face the same issue with different lenses attached to the camera? Try a different focus mode and test again: https://helpguide.sony.net/ilc/2380/v1/en/contents/0405C_focus_mode.html
