Flashing 'O' - how to stop this?
Oldandstressed
New
How do I get to taking photos?
24 REPLIES 24
daveyh64
Enthusiast
We are still not seeing the images you are trying to post.
What are you doing?
Have you replaced the memory card in your camera, or emptied it so you can continue shooting?
When you go to the Sony page with the manual for your camera try to download it as a PDF so you can keep it handy on your computer.
I am using a Mac and to do this you would open the page for the manual, Click on File> Print and then select Save As PDF.
If you are using Windows I guess there will be a similar function.
Once the manual has downloaded to your computer then go to page 33.
danardeng
Contributor
Oldandstressed
New
danardeng
Contributor
You have definitely the flash memory full.
Save all media in your PC and format the card in to the camera.
Oldandstressed
New
Thanks
