Dear Friends
Thanks you for all the help thats been given regarding installing a Firmware update and I've tried all the options to install this to my Sony Alpha a230 DSLR but I cannot open the .APP file that's needed to update my camera.
Please could somebody possibly help by telling me what program I need to open this file as my Windows XP version does not recoginze this.
Many thanks
Norfolklad
Solved! Go to Solution.
Hello Norfolklad
If you have a look at the detailed instructions here:
In particular, for steps 2 and 3 this involves taking the .app file and putting it onto a compatible memory card. The instructions in the link are pretty long but comprehensive and as long as you follow this procedure exactly you will get this successfully updated.
Thanks,
Simon
Hello Norfolklad
Thanks,
Simon
Hello Simon
This is exactly what I was needing. Thank you so much for this, I'm really grateful to you.
Regards
Norfolklad
