50w809c - sound noise/crackling with bass
GELÖST
soniaczziom
Mitglied
Hey,
can anyone with simmilar model run below video on YT and check if sound starts to crackle when bass starts around 0:20 :
https://www.youtube.com/watch?v=BtqiGQd9248
The not-bass boosted version of this song sound OK, is it my tv problem or just the TV speakers cannot handle such bass - on external output home cinema its fine.
¸,ø¤º°`°º¤ø,¸¸,ø¤º° яεα∂ αℓℓ °º¤ø,¸¸,ø¤º°`°º¤ø,¸ ------------------------------------------------------------ COPYRIGHT NOTICE - LABELS AND CONTENT OWNERS READ! Most of the songs promoted on this channel are from submissions or copyright-free channels, such as Non-Copyrighted Media. These songs ...
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
soniaczziom
Mitglied
I found that its caused by DSEE option - i have to disable Clear Sound+ and make sure that DSEE is disabled - it fixes this. Whats strange it only happens when I run youtube when digital TV source is active. If selected source is for example HDMI2 which is PS4 and I go to youtube (build in tv YT ofcourse) - no matter what is the sound settings it works fine.
Seems that it is some interference with digital TV and apps.
10 ANTWORTEN 10
soniaczziom
Mitglied
Anonymous
Nicht anwendbar
Hi there
Thanks for posting back the solution im sure this will help others.
Cheers
soniaczziom
Mitglied
Did anyone else encountered this issue ? Knows why does it happen ?
soniaczziom
Mitglied
I also noticed that it happens not only in this video in Youtube but also in all Android Apps and some other videos.
Overall the sound is very disorted when changing from live TV to an android app while DSEE is activated. Can you report this to SONY ?
Anonymous
Nicht anwendbar
Hi there
I have tested this on my KDL-43W805C and cannot replicate this issue.  I can report it to Sony, but as no one else has confirmed this issue, its hightly unlikely it would be looked at anytime soon.
I do have a current bugs and issues thread going - but im only adding problems that multiple people are experiencing:
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/td-p/2040020
I will keep an eye out though if anyone else reports in with this problem.
Cheers
soniaczziom
Mitglied
Have you used the build-in tuner testing it ? For me it only happens when switching from built in tuner live-tv (DVB-C with CI card) to youtube. Make sure you have standard sound settings with DSEE enabled - because this is what makes the sound messy.
Below video is a good example - when bass starts around 0:20 :
Anonymous
Nicht anwendbar
Hi there
Just quickly - I can confirm now.  Should have used the YT clip you posted originally.
I will get back to you.
Cheers
Anonymous
Nicht anwendbar
I can also confirm the use of the inbuilt tuner (DVB-T /T2) as the source.
When changing to a hdmi source and then using the inbuilt youtube app on the TV - all works ok.
Will add this as an official bug/issue and report it to Sony.
Anonymous
Nicht anwendbar
