BBC iplayer, itvhub at al not working
123DAC
Explorer
I have tried to access the streaming services mentioned above.  I keep getting a message saying an error has occurred please try later. Any simple straightforward solutions please?
4 REPLIES 4
Jo_Jarman
Explorer
Is the TV connected to the router OK?
Have you switched power off or had a power cut?
123DAC
Explorer
No power cuts and all other internet based apps working ok, eg Netflix, Prime, You tube etc, just the above having problems with.
Jo_Jarman
Explorer
Sent from Mail for Windows 10
I just had a similar problem after power turned off but Prime also not working – only one was Netflix.
Found a fix which worked for me – you could try it.
Time was different on TV..............
Went to Date/Time and set setting to take time from network. All OK then.
Cheers
Jo
Tonycv51
Contributor
if checking the time isn't the issue you could try re running the Tv's initial setup (not a factory reset).  Skip the TV tuning part and accept all sony and youview terms and conditions.  Only takes a minute and could be the issue
