Blank screen
profile.country.IE.title
Sassy1
Blank screen
Hi,
I bought a Sony TV in January 2022. In July I noticed when I switched on TV I had a blank screen (purplish tin) and just sound. I turned off TV and turned it back on and it was fine. It began to happen more regularly, maybe twice a week. However what I notice now is that when I turn off and turn tv back on the picture flickers for a while (10-15min) before settling down. I've tried a software update and factory reset. I thought the latter worked as it was fine for about two weeks before it happened again at the weekend. Any idea what's happening here?
5 ODPOW. 5
HannahEd01
Hi Sassy1, that looks like a hardware fault, not a software one. What's the model number of your TV? The software version? Connected devices? Normally, what do you watch? Also, have you tried contacting Sony support? As I believe the service should be booked through them.
Sassy1
Thanks, that's what I thought, I'll follow up with Sony. Model number is KD-43X81J. It has the latest software. The only device directly connected to it is my Sky modem. Sky, Netflix, Disney is what I watch on it.
Anonymous
Nie dotyczy
Hope that they get it sorted out for you soon buddy, cheers.
Sassy1
Thanks. I’ve been in contact with engineer and based on the info, photos and video I sent him he said it appears to be an issue with screen. As Sony don’t replace screens he advised me that Sony will replace the TV.
Anonymous
Nie dotyczy
Oh great! Hope you get lucky with the new TV, enjoy mate.
