Blue Colors
lulek1
Blue Colors
Hello. I have not bought it since a long time. Tv Sony Bravia KD55X8005C everything works correctly, there are no bad pixel lines, etc. only there is a quality problem ... you can see especially on elements that should be white and on the yellows - eg the skin is slightly blue. Of course, I tried to change the options in the image settings.
1 ODPOWIEDŹ 1
royabrown2
Zawodowiec
Look for an option with a name like Colour Temperature. It sounds like you may have that on Cool, but would prefer Neutral or Warm.
My favourite bedtime reading is a Sony product manual…
