Hello. I don't know if it's normal but I noticed that the processor is constantly using 100% sometimes it reaches 80% is it normal? no applications are running in the background because I restarted the TV and factory reset. Is it possible to check which application is using so much CPU power? I also have google tv streamer and it uses on average 30% of the CPU
@Krzysztof31 I believe there is no internal way to measure the CPU usage. If you found an alternative solution, you can share it with us!
