Jaylin431
New
Bravia kd438005
I recently installed Google play, and now I can only get TV channels that are on there. Can I reset to manufacture default settings. If so how?
1 REPLY 1
profile.country.IT.title
rooobb
do not really understand what you did  since google play is preinstalled, in any case just go to setting/memory and you should find the factory reset
