Bug android nougat 7.0 sony 43X80D cant read usb
areagames
hello
i have a problem with my tv sony 43X80D , last week ago i was upgrade firmware android 6.0 to 7.0 ,
before its in firmware 6.0 no problem on usb port. my flashdisk/harddisk can read and play with app sony (video, picture, music) but in android 7.0 my tv cant read usb so i cant play video,music,picture with app sony . but when i used third app like ES file explorer usb can read and play .
so what should i do ?
1 ODPOWIEDŹ 1
Jecht_Sin
Znawca
If you are using a Mac you most likely formatted it using the GPT/GUID partition table. What you should try is to copy all the content in you USB device, format it again using MBR partition table and then copy the files back.
If that is the case I am not sure how ES can manages to see the parttition though. It just shouldn't get mounted by Android.
