Can't add my new Bravia into a Google Speaker Group
profile.country.FI.title
jarisiv
Hi there,
Having a quite weird and annoying issue at the moment. For some reason I'm not able to add my new Bravia with built-in Chromecast into a Google Speaker Group. No problems at all with my other Google Cast devices (Chromecast, Chromecast Audio). It is now just my brand new Android TV that is having this issue. Is it just me or someone else having the same case? Very annoying as looking to complete my plans of having full house multi room audio setup.
With BR,
Jari Sivén
26 ODPOW. 26
Sean_Mc
Moderator
Hi Jari,
So I can look into this, can you let me know the full model number of your TV?
Best wishes,
Sean Mc
jarisiv
Thanks! Model is KD-65XF9005.
BR, Jari
samwise22
It used to be that only Google speakers and Chromecast Audios could be added to speaker groups, then last year they added the ability for certain Chromecasts to be added too. It's not supported by all Chromecast devices, including Android TV's "Chromecast Built-in".
You wont be able to do what you're after. This is down to Google I'm afraid.
jarisiv
Well in that case ("This is down to Google I'm afraid.") this starts to be quite weird as just got a msg from Google product expert as follows:
Check with Sony and see if they have released the update that adds this ability or if they have a proposed date.
Google is able to directly update stand-alone Chromecasts but the code for built-in ones has to go to the manufacturer (Sony) and then they have to distribute it to their devices.
We had the same issue with Audio Groups for smart speakers... stand alone Chromecast Audios got the feature but it took months for speaker manufacturers to roll their updates out.
Sorry for the delay.
jarisiv
What's the situation with this one Sony?
BR, Jari
The_Black_Rose
Specjalista
Hi jarisiv,
What is the model number of the TV?
Cheers,
The_Black_Rose
jarisiv
Hi,
Thanks. Are you able to check couple posts above?
BR, Jari
The_Black_Rose
Specjalista
Hi Jari,
I'd recommend checking the Chrome Cast Built-in version by following these steps: Press on Home- Settings - Apps - Chromecast Built-in. You can check with Google if this version is compatible with the Google speaker group function or not.
Cheers,
The_Black_Rose
jarisiv
Hi,
Chromecast Buil-In version is 1.36.140076.
Is that the latest one?
BR, Jari
