Hi
just bought kd65x9305c but cant upgrade the firmware. if done by internet it stops at 81% everytime saying (error 2123) that a problem with server, if done by usb it again stops at 81% copying file and then crashes tv!
please help
Hi there
Ive sent you a private message with some instructions. Let me know how you get on.
Cheers
thank you Quinnicus but doesnt seem to work as you described 😞
I've replied to your email
thank You it worked , you rock!
Your Welcome
Hi.
Quinnicus, I'm from Brazil.
I can apply this solution?
XBR-55X855C
Thanks.
Hi there @didievilempire
Ive sent you a PM, with the instructions. As you are in Brazil and different firmware etc, I am unsure if it will work or not - but it doesnt hurt to try. I had 1 person from the USA ask as well, but these instructions failed.
Give it a go anyhow.
Cheers
Hi @Anonymous
I have 55x8005c but cant upgrade the firmware. if done by internet it stops at 67% everytime saying (error 2123) that a problem with server, if done by usb it again stops at 67% copying file(error 2123) and then reboots tv!
please help
thank you
Hi @dimitrisv99
I have sent you a private message with some instructions - let me know how you get on.
Cheers
@Anonymousthank you very much!!!!it works for me!!!!you are the best!!!!
