Freeview KD-50X75XL
SOLVED
refpjb
Explorer
Freeview KD-50X75XL
Please can you advise if this model has Freeview player inbuilt and if so, how do I set up? Many thanks
1 ACCEPTED SOLUTION
Accepted Solutions
LightFoot
Specialist
Hi @refpjb
I tried to reply yesterday,  but it was impossible to log on to the community.
YouView (and Freeview Play) both require an aerial and Internet. For Internet only you need Freely or something like a BT/EE box in IP mode (requires BT/EE broadband and subscription).
The KD-50X75WL does not support Freely, so what you are asking is impossible.
Freely TVs.
4 REPLIES 4
LightFoot
Specialist
Hi @refpjb
Do you mean KD-50X75WL and Freeview Play? KD-50X75XL is not supported in the UK.
The KD-50X75WL is a Google TV which has LIVE TV & Catch Up (YouView) and not Freeview Play. However you can add a Freeview Play box to any TV for about £70. Freeview Play Box.
refpjb
Explorer
Hello Lightfoot,
Thanks, yes KD-50X75WL. Can you clarify how you set up YouView to run off WiFi as opposed to an aerial or satellite.
Many thanks again for your help.
LightFoot
Specialist
Hi @refpjb
Freely TVs.
refpjb
Explorer
Thank you Lightfoot 🙂
