Green screen on oled
profile.country.IE.title
Josoap
Member
hi  can anyone advice on how to fix a green image on the screen.  eg would be if there is 3 people on the screen the centre would be grey while the other people would be green.  problem only started over the last day . so don't know what the problem could be
thanks for your help guys
2 REPLIES 2
Peter_S.
Genius
Hi Josoap,
Please have a look at the following article and see if it can help you to fix the issue:
https://www.sony.co.uk/electronics/support/televisions-projectors-oled-tvs-android-/articles/0017347...
Cheers
Peter
Josoap
Member
Thanks Peter for your help.  I seen it on the tv it has a image refresh option on my tv . I must try that and see if that will sort it.
Thanks again pal 👍.
