How to connect my non Sony Bluetooth headphones
edward036
Novo
hi,
i have a sony KDL43W807 and would like to use my non Sony Bluetooth headphones. How do I do it, thx
3 RESPOSTAS 3
Anonymous
Não aplicável
Hi there
Unfortunately none of Sony's TVs are able to pair with any bluetooth headphones.  This is because of the lack of the A2DP bluetooth profile which is required for audio.  This has already been put forward to Sony as a most requested feature.
So what can you do?  You will need to purchase a bluetooth transmitter that plugs into the TVs headphone socket.  A couple of suggestions are:
https://www.amazon.co.uk/Aukey-Bluetooth-Transmitter-Technology-BT-C1/dp/B00PI6EEVW/
https://www.amazon.co.uk/dp/B00Z61YAAE
Hopefully this helps.
edward036
Novo
That's crazy!!! I bought a Sony Bravia tv, sound bar and ps4.
Just so Sony can tie you into buying their headphones....
Sent from my iPhone
Anonymous
Não aplicável
Hi there
As i mentioned on twitter (assuming it was you) - its not the case of the headphones not being Sony, its the case that Sony TVs do not support ANY bluetooth headphones.
Cheers
