input source
gawatso15
input source
The input source bar - showing HMDI3 for example gets getting displayed quite often for example when moving the mouse when I'm using a PC connected to the TV, or when changing cable channels.
It stays displayed for about 5 seconds, but I only want to see the input source when I change it.  Is there a way to reduce the times this gets displayed?
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
LightFoot
Specjalista
Hi @gawatso15   The work-a-round is to disable it. Look in Settings, Channel setup. Just guessing as you didn’t tell us your TV’s model number which is always the starting point 😀
2 ODPOW. 2
LightFoot
Specjalista
gawatso15
the model is  KDL-37V 5500
I will give the settings a go
thanks
Gary
