Hi all
So 16 months TV go dark soon as I switch on.
I get a menu for 1 sec then black.
I done an hard factory reset. No luck...
I can see the white light round the edges.
If I shine a torch can't see any image
I do get sound.
I assume this is commen.
On ringing Sony.. They said seem some power failure to a component...
Any idea what this is and where I can buy one... As it out of warrenty... Really cant afford a new TV
Thanks
Hi @Marmite79
Unfortunately your options are limited. Their may be a locally tamed TV repair person that may be able to help or an expensive Sony Repair Centre booked in through Sony UK Support . Are you sure it is out of warranty, I would always expect a 5 year guarantee with Sony TVs.
