KD-55XD8599 Problem since Marshmallow update
Deblob
Explorer
Hi all.
New to the forums so please excuse if I've posted in the wrong thread etc.
Basically, since my TV updated to Marshmallow around 2 weeks ago I've been having an issue with apps running and leaving a faded square box in the top left corner.
Sometimes it's smaller but sometimes can r half the screen.
Happens only on Apps (Netflix, Amazon, Kodi) and not on any HDMi channels.
Seems to happen possibly 80% of the time and I've not found a way for it to stop.
I've reset the TV to factory settings numerous times and also restored with current firmware that i downloaded from the Sony site and flashed using a USB stick.
Also I've ensured that all the apps are up to date via Google Play Store.
Can anyone confirm wether this is a one off in my case or wether the issue is more widespread?
I've attached a few sample images for you guys to see.
Many thanks.IMG_20170319_234053.jpgIMG_20170319_234101.jpgIMG_20170319_235356.jpg
21 REPLIES 21
Anonymous
Not applicable
Hi there
Ouch, that is not good.  This is the first time I have heard this issue to be honest, so unlikely to be a widespread issue (famous last words...)
Question though, how long does this faded square box stay on the TV for?  Does it ever go away?
Thanks for the pics - it clearly highlights the issue.
Cheers
bigjohn1980
Explorer
i too have this problem but it was before the update but after having a new board put in
bigjohn1980
Explorer
ps here is a utube cideo that i have done
https://youtu.be/Fb1dG43aUIs
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
Anonymous
Not applicable
Hi @Deblob
I have escalated this issue to Sony support for them to investigate and resolve.  I suspect that the Marshmallow update is coincidence as to me this is more hardware related.  But I am purely guessing to be honest.
Cheers
Anonymous
Not applicable
HI @bigjohn1980
Can you please confirm the model number of your TV?
Cheers
bigjohn1980
Explorer
Hi@Quinnicus
Thank you for you input my tv is a kd-65xd8599
I.have been emailing sony for.about 4 weeks now about this but keep asking.me to do this and other but nothing is working but i have also got other problems with tv resetting not turning off.  I did have it repaied about 4 months ago by sony repair center but it still resetting and also there in no serial number.in the system setting so i got them back to be told there was nothing they could do about it
I did.post a post.on here about it
Thank you
John
Spoiler
Anonymous
Not applicable
Hi @bigjohn1980
Do you have any Case ID numbers that you could foward to me via Private Message?  This is so I can forward everything back to Sony and they know specifically the case number etc.
I do remember your other thread:
https://community.sony.co.uk/t5/android-tv/xd8599-now-says-8505/m-p/2252769
Cheers
Anonymous
Not applicable
For completeness of thread - I have escalated @bigjohn1980 issues to Sony too.
MarkF42
Explorer
I have a KD-55X8005C and have the same issue since MArshmallow update.  I have only noticed it in Amazon - a rareky use any other apps.  The top left corner seems to be in HD / much brighter than the rest of the screen.
To resolve I stop the play and resume. Usually fixes first attampt, but last week took 3 or 4 attemps to clear it on one occasion.
Happening on lots of different recordings - all on Amazon Prime.
