KD43XG8196 & STR DH800
paumajor
Explorer
Is anybody else running the old STR DH800 AV with the KD43XG8196? If so, would like to know what settings I should be using. Or should I be looking to upgrade to the STR DN1080?
Thanks in advance, Paul
2 REPLIES 2
Mick_D
Moderator
Hi @paumajor
You don't mention any issues with your current setup; which settings are you having problems with?
Mick
paumajor
Explorer
Hi Mick,
Thanks for your reply, greatly appreciated. I’ve taken the plunge and purchased the DN1080. Now just getting used to driving the new piece of kit.
Best regards, Paul
