KD49XF9005 stand
kemulha24
KD49XF9005 stand
Hi, I am contemplating buying the KD49XF9005BU tv but the legs (stand) it sits on are wider than the unit I intend to put it on. Is it possible to fit the legs at the opposite sides so that they point inwards. The guys in John Lewis tell me it is but I don't want to buy it and then find out it's not possible. A quick look at it in the shop suggests they might.
6 ODPOW. 6
profile.country.IT.title
Marino.Manolo
Genius
Because of these (indicated by the arrows in the image) I think it is not possible:
Manolo
kemulha24
Thanks for your quick response. It certainly looks like they are handed so it's back to the drawing board to find something as good at the right price.
Marino.Manolo
Genius
In your situation you would need a table stand to be mounted using the VESA mount.
Manolo
kemulha24
I have ordered one thanks
Marino.Manolo
Genius
You're welcome...
Manolo
Andyg4536
I've seen a video on YouTube where this is done but personally I wouldn't as the TV is quite wide
