KD55X9005C tv , Usb 32gb hard drive fitted to hold extra apps......
petepots
Guys
Let me try and explain for example the apps VLC is downloaded and stored on the external Usb drive, also I want to put it on the favourite menu, no problem all works great untill I goto stand by, next time I put the TV on they have gone off the favourite menu, so I have to put them back on.  Why wont they stay on the favourite menu.
16 ODPOW. 16
petepots
On my new drive, it work great, no problems.   works with cold start after complete power down.  When you first access the drive say in the morning it take a few seconds to fire up but it good
My first drive was faulty, but new one great
Joe_Dohn
Specjalista
@Lassesu Are you able to try a new hard drive as well?
profile.country.SE.title
Lassesu
I plug in a hard drive full of movies and pictures. It works well.
But you do not get Dolby TrueHD, DTS-HD MA, DTS: X Master Audio. Sony has blocked the possibility from all apps to send out via e-arc.
Piscie
Hey Lassesu, have you tried to remove the USB stick before turning off the TV and plugging it back after powering on, had it make any difference?
Lassesu
Have not tested this.
Pentium_Gladio
Specjalista
Hi Lassesu,
Let me know if this works on another HDD. It might be related to it i am guessing.
Cheers,
Lassesu
Have tried with two different hard drives and through network sharing. Equal to everything.
Someone who can test share a file with the different audio formats and see if it works for you but Sony TV.
