Hello there.
I have an Apple TV 4K connected to HDMI port 2, and when I try to watch something, either purchased from iTunes directly, or streaming on Disney+, Netflix or Amazon I get terrible pixelation in the black and dark areas. Is this an issue with this model displaying HDR images?
All of the settings are set for HDR - not sure what else to try. Thanks!
Hello @jsnbts,
for Netflix and Amazon you should be able to pull up the stream-statistics to check whether or not you are getting a lower bitrate stream for some reason which would explain these artifacts.
- Nic
