Where can i buy a a screen replacement in the UK. Does Sony have screen replacements
Never heard of a screen replacement on Tv let alone a 65" one. if the screens broken itd probably be cheaper just buying a whole new tv if honest. What exactly is wrong with it.
Nerf gun war went wrong sniper took out the screen instead of the target 😅. The sniper is 5 years old 🤦🏿♂️.
😅 Unfortunately a screen makes up around 2/3 of the cost of the unit, adding labour and everything to that i suspect the cost to replace it would be more than what a new tv would cost. nerf gun, i thought they only fired foam projectiles
😂😂😂No pocket money for a long time then lol oh dear sorry to hear about the TV, you could ring around a few places but youd probs get the same answer, it is frustrating because the SDony is not a cheap tv i wish you luck..
