Делитесь своим опытом!
I bought above-mentioned Sony TV everything was good installed red bull TV, a few other apps and kodi, I put build in kodi and it worked fine, next time I went to Google play store it say's "cannot connect to the Internet" kodi is still working so android TV is getting Internet, but Google play store says it has no connection. What am I doing wrong.
Hi there,
We responded to your previous message about this. Could you please take a look, and let us know if the Firmware update helps?
Thanks,
Owen
